Rotate
Rotate
zs-17
Message 1 of 24
Rotate
zs-17
Hi
I have a photo with a sweep in place frame, I would like to rotate from the top to have a distance between the photo and the wall. How can I do it please?
Replies (23)
Message 2 of 24
Host the sweep on a reference plane instead of the wall face, then you can tilt the reference plane and the sweep will follow.
Message 3 of 24
ennujozlagam
hello, rotate or align ? if align > just go to modify > align > pick your line where you want the photo to be and pick your photo. thanks
Message 4 of 24
zs-17
Align Tool works with either the sweep or the photo. But not both of them.
Message 5 of 24
zs-17
This is what I tried first. When I select the sweep and photo, I don't find an option to pick a new host.
Message 6 of 24
ennujozlagam
hello, i'm assuming your frame is a family > edit your family frame < untick always vertical and load again > overwrite existing and see if helps. then rotate with your reference plane guide. thanks
Message 7 of 24
ennujozlagam
hello, need to align your photo to your frame then lock it before you can rotate them together. thanks
Message 8 of 24
zs-17
No, I don't have this option
Message 9 of 24
zs-17
They were aligned, When I align them, only one of them will be aligned. I also tried to group them. But I didn't succeed.
Message 10 of 24
ennujozlagam
hello, photo need to align then to the frame 4 sides and lock (if you see the padlock lock it). you cannot group them together without locking it, your photo will left behind. thanks
Message 11 of 24
zs-17
Hi
There is no locks for any. I tried to create a new frame than will add a photo, I tried to pick a new inclined host as Toan said. It always guide away from he section I'm into. I still can't succeed.
Many thanks
Message 12 of 24
ennujozlagam
hello, can share your frame and photo so can check? thanks
Message 13 of 24
zs-17
Yes. Thank you. Section 1 will guide you to the frame
Message 14 of 24
ennujozlagam
hello i created just a trial family then i group them and load into project file and can be rotated. please see screencast and file attached. thanks
Message 15 of 24
zs-17
Hi. Basically this is what I need. But I didn't understand it. I have to watch many time and try to follow. You know, I don't understand why many thinks are complected in Revit. I will back to you later.
Many thanks
Message 16 of 24
zs-17
Is there a way to download your screencast to my computer?
Message 17 of 24
ennujozlagam
I'll do it tomorrow. Its late here. Provide me your email add I will send you tomorrow. I'm out now. Thanks
Message 18 of 24
ennujozlagam
Hello, what did is create the frame and photo as a family. Open a new family select generic model.rfa and do your frame with photo and save load to your project file and follow my screencast video to rotate. Thanks
Message 19 of 24
zs-17
Hi
I do not expect instant reply for any post. The steps looks easy, for me are not. I'm new to Revit, and I didn't work in Family before. Since I already have a rame and a photo, can I past in a generic family instead of creating it again? any way this is my email and thank you for being patient and supportive.
ziadsourany@gmail.com
Message 20 of 24
Hugh_Compton
