ROTATE VIEWPORT WITHOUT ROTATE TITLE ON SHEET
jorgedacunha60
jorgedacunha60
HOW DO YOU ROTATE VIEWPORT WITHOUT ROTATE TITLE ON SHEET?
George!
RobDraw
NO NEED TO SHOUT!
Have you tired rotating the crop region?
Rob
constantin.stroescu
so as RobDraw already mentioned:
  • in Sheet> Activate View and Rotate the Cropped View , then Deactivate View...as you see the View has to be cropped to do this...
Constantin Stroescu
LyleHardin
Get 'inside' the view. Pick on the crop boundary as if you are going to edit it. Rotate it. Then adjust it as necessary.
It will rotate the view OPPOSITE the direction you rotate the frame, so it takes some getting used to.
mike_tomasurvey
Sorry, I am not sure why I got an email to help. Didn't realilze this was a Revit post. Wierd. I have deleted the post. Sorry again.
Mike
RobDraw
Those AutoCAD commands will not work in Revit!
Rob
mauricio_mssf
Follow these steps
1 - Click on Show Crop View
2 - Modify the view orientation for Project North
3 - Select the viewport and rotate.
You can see in the screen video
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/27a...
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
