ROTATE VIEW ON SHEETS?
Message 1 of 10
I have 3 standalone small shelters on a single site but all 3 shelters are at different angles.
Pls advise what is best way to show all 3 building plans views in a single sheet but plans have to be ortho.
Replies (9)
Message 2 of 10
If you have each of the buildings as separate floor plans you can unhide the crop region for each view, then rotate it to the correct angle and hide it again.
Message 3 of 10
Just a note, you need to rotate the crop region the opposite way you want the buildings to rotate
Message 4 of 10
Thanks Alex and SKoulis.
Alex, sorry I dont know its a dumb question but all 3 shelters are on same level so how do I model as different floor plans? Thanks
Message 5 of 10
If you right click on the view and duplicate it as dependent 3 times (and rename as appropriate), then crop down each view so it only shows one of the buildings. You can then leave the original view showing all 3 buildings.
Message 6 of 10
Alex,
Do you mean to duplicate floor plans views just for purpose of rotating crop views?
I tried using callouts but noticed that my CAD link survey plan doesnt appear on callouts. How do I make CAD link visible?
Thnaks
Message 7 of 10
yes. duplicating as dependant should keep any annotations or cad underlays consistent on all the views
Message 8 of 10
Oh OK Alex, thanks for fast answer to my 1st question.
Is there a way to make CAD links visible in Callouts?
Message 9 of 10
if you copy it, then paste aligned to the same place it should work
Message 10 of 10
Thanks Alex
