Rotate the building (default 3d view)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been doing the research on this topic but couldn't find a good solution that works.
This is what I'm dealing with.
I was given a Revit file that has 2 different grid lines orientation. See attached image.
The one on the left is for the A2 series (overall floor plan) "portrait orientation" and the one on the right is for the A6 series (overall RCP) "landscape orientation"
You can tell by the 0,0 insertion point
I don't understand why it's setup this way because normally these 2 series have the same exact set of grid lines and orientation.
Anyway, I assume the A6 series views got rotated because when I click on the default 3d view button at the top, it matches the grid lines orientation on the LEFT.
My question is:
How can I make the default 3d view of the 3d model to match the grid lines orientation on the RIGHT (BLUE COLOR)?
I want to export the revit model as DWG file so that the orientation matches the one on the right.
Thanks in advance.
