scalelabel does´nt work, wrong parameters?
5 ANTWORTEN 5
Nachricht 1 von 6
oskar.fahlen
257 Aufrufe, 5 Antworten
Hi! I have some trouble with my sheets..when i put views into my sheets the sheets doesnt automatically add what scale the views are. I guess it has to do with some parameters? the only way ive manage to se the scale is in inches but i want it in metric..
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: oskar.fahlen
Are all the views having the same scale? If not then the sheet will show As indicated.
Nachricht 3 von 6
oskar.fahlen
The views have different scales. It doesnt show As indicated, it doesnt show anything at all. All the info i want from my views gets added to the sheet except the scale.
Nachricht 4 von 6
curtisridenour
If the Label in the title block family is not set up correctly, use the method shown below.
Nachricht 5 von 6
Share you titleblock family here.
Nachricht 6 von 6
Huh?
Something doesn't add up here.  I got to see this.  Post your Project (RVT).
