Rotate scope/view box on x/y axe
chix88
chix88
i've seen a post that you can not rotate the section box along the x/y axe, the post was from 2019 and i was wondering if it still not possible to do it
so basicly , i want to have the view to cut my builduing diagonaly Screenshot_6.pngScreenshot_5.png
but i can only totate it on the Z axe.
The post from 2019
I like to see this post you are talking about.  As far as I know, 3D Sections and Scope Boxes view must have parallel vertical axes.
chix88
i linked it in my first message, you were the one who repended to it
you've said it was impossible , but since it was 3 year ago, i thought maybe there was an update or a way to do it now
here is the post
https://forums.autodesk.com/t5/revit-architecture-forum/rotate-3d-section-box/m-p/8663945#M233366
You can rotate both the section box and the model.
If you want to only rotate the section box to clip the model at an angle then No, you can't without some workaround.
here is the post
I just had a speed-reading accident. I thought you said you've "seen a post that you can rotate the section box".  I missed the "not". 😉
RobDraw
Yes, you can rotate it in a plan view.
Rob
