Hello Revit community,
this is a simple quest but it is taking me insane amount of time.
I just want to know how to adjust this part, marked in the picture.
Thank you!
Good day
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Adjust it how?
BTW: all that linework you are seeing is most likely Symbolic linework that has been drawn in the Plan View of the Window Family. That's where you would need to go to "adjust" the linework.
Edit Type and see the type properties give you any parameters to adjust the sill. if not, edit the family and adjust it, or add dimension parameters so that you can adjust it more easily in the project.
