Rotate object
Rotate object
Szigeti.Eduard
Message 1 of 12
Rotate object
Szigeti.Eduard
Can please somebody tell me how to rotate the highlighted element to face to me?
Replies (11)
Message 2 of 12
mauricio_mssf
I didn't quite understand what you meant, the space bar or the rotate tool is not working?
If your intention is to rotate the furniture horizontally and you are not getting it, it may be a family floor based or face based. Please try to explain a little more and place the family.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 3 of 12
Szigeti.Eduard
Is just that when I push the space bar the unit just flips on the other side instead of looking towards me.
I have the same problem with the worktop.
I can't place it over the cabinets .
Message 4 of 12
mauricio_mssf
Note that in your family you have an orientation controller, which only allows you to rotate vertically, enter the family and  delete it.
If you want to insert these controllers again, click File >> Control. 
These tools are for choosing and restricting the flip direction.
Message 5 of 12
Szigeti.Eduard
Thank you for your answer.
But I can't delete the control as is not active
Message 6 of 12
mauricio_mssf
You cant' delete on 3d view, Did you try at the reference level?
Message 7 of 12
hmunsell
the issue may be how the family is hosted. can you upload the actual family for us to look at?
Howard Munsell
Message 8 of 12
Szigeti.Eduard
Eventually I managed to rotate them by editing the family and rotating in the front view.
 The problem is now that I can't put them in their place as I can only move them up or down.
Message 9 of 12
hmunsell
When moving the object:
  • select the object,
  • pick Move
    • uncheck Constrain
    • Check Disjoin.
that should allow you to move it it other directions.
Howard Munsell
Message 10 of 12
mauricio_mssf
Your family is face based with a height limitation, you have to apply it on the work plane or on the floor, or on any horizontal face, in your image it looks like you are applying it on the wall, so you will never be able to put it in position correct e flip.
Message 11 of 12
s.borello
Can you use the align tool or is it not working for you?
Message 12 of 12
Szigeti.Eduard
I know that I am a beginner but I just don't know what I do wrong.
Please see attached revit file.
