Rotate Conceptual Mass Face
PhilvK
Advisor Advisor
Message 1 of 9
PhilvK
In a Conceptual Mass, isn’t there a way to rotate the face shown by the green “X” below onto the position by the red lines? I  know I can drag it out with the arrows (not shown), but I need it be at a specific angle.
Replies (8)
Message 2 of 9
PhilvK
I figured this one out too. You go to the elevation view perpendicular to the face you want to rotate, select it, then rotate it. (Still learning things)
Message 3 of 9
Isn't this rotating also the top face?
Message 4 of 9
Alfredo_Medina
You could simply move that top edge out.
Something similar to what I replied to you in this other thread:
http://forums.autodesk.com/t5/revit-architecture/mass-help-with-basics/m-p/5550761#M89475
Message 5 of 9
PhilvK
Alfredo - Yes, it is the same thing. I just wanted to know how to rotate that face out at a specific angle, not just by length by moving the edge. I think I understand it now. Also, thank you for reminding me of the earlier thread!
Message 6 of 9
PhilvK
Lucian - Yes, you are correct. I was kind of hoping you could stretch the corner as you could in SketchUp and the top would stay level. Oh well....
Message 7 of 9
Hi PhilvK,
If you still want to give as input an angle you can add some parameter to control how much the top edge will be shifted.
Please check the video below.
https://screencast.autodesk.com/main/details/c1e8c19c-8140-4f9e-a6aa-c2995b30fc7b
Hope this helps!
Lucian
Message 8 of 9
PhilvK
Perfect! Thank you very much!
Message 9 of 9
You're welcome!
