Rotate a door panel
16 REPLIES 16
Message 1 of 17
1906 Views, 16 Replies
Rotate a door panel
I trying to rotate the door because when I insert then in curtain wall put one in a side and the other in the other.
I can't use arrows right/left as in pic 2.
I've try to modify the family without a good result because rotate th panel in family the handle go out of panel.
How can I do?
Rvt attached.
Thank's
Rotate a door panel
How can I do?
Rvt attached.
Thank's
16 REPLIES 16
Message 2 of 17
I can't open your file, it says it contains incorrect schema. Which Revit version did you create it in?
Message 3 of 17
Alan.johnson1970
Alan.johnson1970
I cant open file either, can you attach another copy.
AJ.
AJ.
Message 4 of 17
martijn_pater
martijn_pater
Seems like you're using a curtain wall and cw panel, you can replace it with one that turns the other way. The control is probably not useable, because you have an offset to the panel which would place it outside the door... ?
Message 5 of 17
in reply to: Alan.johnson1970
Now?
Don't  know if are damage inside some file.
Now?
Message 6 of 17
martijn_pater
martijn_pater
Added a control in other direction in the family. Load attached into project.
edit: ow renamed it, just use the same as in your project, just rename is as it was Anta Singola_sx_addedcontrol.rfa
(or replace the panel family)
Message 7 of 17
Alan.johnson1970
Alan.johnson1970
As martijn said just add in/out and left /right flip control
AJ.
AJ.
Message 8 of 17
@Alan.johnson1970  how can I do to create an other copy of the project?
If do copy/paste i haven't level and room tag etc...
Message 9 of 17
@Alan.johnson1970 @Anonymous
if you view the project attached in this message I redo the curtain wall from here.
Otherwise next time i reattahced the project it isn't readable.
Thank's
Thank's
Message 10 of 17
martijn_pater
martijn_pater
@Anonymous Either download and rename the file I attached in post#6 to its original family name and reload into the project. Or try to edit the family yourself, then create and add a flip control to it in the other direction.
Or was that a new question? Not sure what youre asking in post#8, seems like you are trying to copy everything in a new file and are missing some families etc...? You could transfer project standards from the original under manage tab, but why not just save as new file?
Message 11 of 17
s.borello
s.borello
use spacebar before you click to place your door family.
Message 12 of 17
in reply to: s.borello
@martijn_pater I notice revit have a problem and that I use is a recovery file so is for this maybe the other can't open the file.
i donwload from new the file in a previous post but is my curiosity undrestand how can I do if I have to move a project in an other file.
When I tryed before more of the part are pinned so i can't transfer in an other.
You say "You could transfer project standards from the original under manage tab" in which way please?
Message 13 of 17
@Alan.johnson1970 @martijn_pater
I achieve on the goal but in my family if click on it there isn't your menu "double horizontal"
Attached the family
Attached the family
Message 14 of 17
@s.borello spacebar is to change from inside to outside and vice-versa.
Not right/left.
Not right/left.
Message 15 of 17
s.borello
s.borello
My bad, that's what I thought you wanted to do... good luck!
Message 16 of 17
martijn_pater
martijn_pater
@Anonymous Try opening the file and click audit when doing this (below left) if your file won't open.
When editing the family, to add a flip control left/right, click on create, click control under control tab, then click control type double horizontal, then click the position to show in the family. This is how I edited the family file I attached above.
Message 17 of 17
RDAOU
RDAOU
Attached the family
See the animated gif capture below
Attached the family
