Paint inclusion in wall assembly?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
474 Aufrufe, 1 Antwort
Hi all..
is it possible to include paint as a wall layer? the problem is thickness..
need this in order to calculate paint..
This is underground floor coating..
Thanks!
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: Anonymous
@tareqathamnehNJJCA
You do not need to add a layer for paint to calculate it's area,
  1. Using Quantities Schedule you can calculate based on the wall area and/or use a calculated value parameter
  2. Using Material Take Off schedule you can add the Parameter "Material: As Paint" and use that to filter the schedule (Below Screencast)
  3. Or if you are using Parts, you can apply the same principle as item 2 above
