Rotate 3D section box
gifthelper01
Message 1 of 9
gifthelper01
Hi all, I would like to rotate the 3D section box along x/y-axis.
However, I found that it could only be rotated along z-axix(plan view). May I know the method to do it? Thanks.
Original section box
Expected section box
Replies (8)
Message 2 of 9
You can't do this with a Section Box.
What you are ultimately trying to achieve?  Maybe we can suggest another way to get there.
Message 3 of 9
gifthelper01
Thanks for your reply. May I know is there any method to create clip box/ scope box in that orientation?
Actually I would like to have a 3D cut like below photo.88641F2B-38F9-4E0C-BC13-6639B3451ADA.png
Message 4 of 9
You can orient the 3D View to angled named Ref. Plane.
Orient to a Plane:
...go to a Section View and draw a Reference Line at the angle you want, Name the Reference Plane. Then return 3D View, right-click on View Cube, select Orient to Plane, and Select the Named Reference Plane as  Workplane.
Message 5 of 9
- If you are okay with showing steps, you can use different scope boxes for the 3d views and complile them on sheet
- If you want the angled clipping plane, create parts, divide parts, exclude parts you don't want to show, then set the 3d view to show parts
Message 6 of 9
...are you modeling it that way -- or viewing it that way?
Message 7 of 9
gifthelper01
I would like to have a view like that instead of having a model.
But I still fail to make that view by using "orient to reference plane.
1. Make a reference plane
2. Orient to the reference plane on 3D view
3. Photo 3 shows the oriented result
4. The section box is still aligned with the box which fail to cut an angle on the box
Message 8 of 9
Sorry for the misunderstanding, @gifthelper01.  I wasn't suggesting that Orient to Plane would transform the Section Box -- only create a working view that was orthogonal to the cut plane.  As far as for rotating the Section Box the way you are wanting;  I've already indicated to you that that is not possible.
Message 9 of 9
OonaghG
You can make a section and do a 3d of that : https://www.seiler-ds.com/make-2d-section-become-3d-view-revit/
