Need help joining floor and wal layers
rattywolf
Message 1 of 21
rattywolf
I need to join finish layers smoothly, here is the picture where I marked layers' priority.
Replies (20)
Message 2 of 21
Is this what you are talking about?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
If not, can you provide a little more clarity of what you are trying to do?  It's not clear to me from your screenshot.
...Like this?
Message 3 of 21
rattywolf
Yes, I just want thin layer on top of the floor join with thin layer of wall. The other layers are connected correctly now, I highlighted borders of wall and floor to make it clear. If I extend floor a bit, it extends the core layer, which I don't want to
Message 4 of 21
Are they the same Material?
Like this?
Message 5 of 21
rattywolf
Yes, same material, same priority index
Message 6 of 21
Did you use the Join Geometry tool?
Message 7 of 21
rattywolf
Yes
Message 8 of 21
Tell you what; post your file and I'll see what's going on.
Message 10 of 21
It's hard to maneuver around in your file because of the language.  But first thing I noticed is that you are Phasing construction.  This may be the root cause of your issue. Is the Wall and Floor in the same Phase?
...I think you posted the wrong file. This one is a Template (rte).  There's nothing modeled in it.
Message 11 of 21
rattywolf
Yes, they have the same construction phase and demolishion phase is set to none in both floor and wall
Message 12 of 21
Can you post the rvt? And tell me what view to open. I'm not bilingual, so it's a little difficult to navigate around in it.
Message 13 of 21
rattywolf
https://www.dropbox.com/s/1x97sbvort6ecv5/cinema.rvt?dl=0
You can open 3d view, this would be the easiest way to figure out the structure and what I'm aiming for
Message 14 of 21
Like this?
Message 15 of 21
rattywolf
Yes, that ceiling part too, but I was originally asking about amphitheater steps, could you please look at them as well?
Message 16 of 21
I can't find it. Show me a picture of what I am looking for. Maybe tell me the name of the view too.
Message 17 of 21
rattywolf
Message 18 of 21
like this?
Message 19 of 21
rattywolf
Yeah, exactly. How to achieve this?
Message 20 of 21
Floor needs to fully overlap the wall, and then modify wall to unlock layers so you can extend them.
