Rooms cant be placed
pflanneryD8HHV
Message 1 of 29
pflanneryD8HHV
Existing conditions are set up all exterior walls are existing and all new unit partitions are new. i have checked all things i could think of to why i cant place any rooms in specific places within a building model. all walls are room bounding and all parameters match in adjacent areas which have rooms placed, nothing is hidden, without using room separation lines i should be able to place rooms in the white spaces, but am denied the ability. any ideas ?
Accepted solutions (3)
Replies (28)
Message 2 of 29
likely the cut plane of the view is higher than the room's upper limit.
Message 3 of 29
syman2000
Couple of things to check.
1. Check and see if the exterior wall is room bounded
2. Set the computation height to value other than 0
3. Check and see if there is plan region in that location
Message 4 of 29
pflanneryD8HHV
I have not found any plan regions and all other settings make sense as i can place rooms in most of the building except those 2 places
Message 5 of 29
pflanneryD8HHV
i checked that , it is not the lower than the room upper limits
Message 6 of 29
Any floor finish in the rooms?
Message 7 of 29
syman2000
Is there floor or roof floating in that area? Cut a section so we can see where the rooms are at.
Message 8 of 29
pflanneryD8HHV
negative still early in the development of the project and the only plan region used in on the penthouse level
Message 9 of 29
pflanneryD8HHV
all settings are the same for all levels that is what makes this so strange
Message 10 of 29
pflanneryD8HHV
Message 11 of 29
SteveKStafford
Computation height is quite high, that is usually much lower.
Steve Stafford
Message 12 of 29
pflanneryD8HHV
it was at 3'-0 i changed it to see if it made a difference , and no it did not
Message 13 of 29
syman2000
One way you can test is add arbitrary room boundary separation and add room to those region. That way you can isolate section area that is causing the issue.
Message 14 of 29
pflanneryD8HHV
thanks good idea it is anything above the column line that the room breaks
Message 15 of 29
syman2000
Great at least we are getting somewhere. Now check and see if the column & exterior walls are set to room boundary.
Message 16 of 29
SteveKStafford
It's usually 0'-0". Make sure there are no floor elements that are room bounding and above the level.
Steve Stafford
Message 17 of 29
pflanneryD8HHV
all rooms are set to room bounding on all floors, all walls are set to room bounding on all wall types (highlighted orange)
Message 18 of 29
pflanneryD8HHV
as you can see by the images other rooms have been placed and all of the settings are typical, there is nothing in the spaces that a room can't be placed to interfere trying to get this done without the use of room separation lines
Message 19 of 29
juliar123
Do you have all you worksets turned on? Is there something hidden on a turned off workset?
Message 20 of 29
pflanneryD8HHV
all worksets on
nothing hidden
rooms in other locations on the effected floors
it is not a design option
it is not a phasing issue
it is not a plan region sisue
it is an anomaly to say the least i  have never seen this before
