Roombook Buildingbook Areabook Extension Update 1 for Revit 2018
rui_es_pacheco
Message 1 of 30
rui_es_pacheco
After installing roombook... plugin, revit started to lag between view windows.
Is there some fix?
Thank you
Replies (29)
Message 2 of 30
Viveka_CD
Hi @rui_es_pacheco
Can you confirm if you have the latest updates installed from your Autodesk Desktop App for your Revit version?
Try repairing Revit and see if it helps resolve the issue.
Looking forward to hearing from you.
Message 3 of 30
rui_es_pacheco
I have latest app and addin installed.
I already repaired revit, and roombook, still laggy,
I already unistalled all revit and reinstalled and still laggy.
anything that i can test more?
Thank you
Message 4 of 30
Viveka_CD
Hi @rui_es_pacheco
I'm sorry to hear about the performance lag.
If you disable the roombook extension, is Revit still slow? If it is then we have to look at your journal to investigate further.
Does the performance lag when you use the extension? or when you work in a specific project/ view?
Check if you Revit version has system requirements and hardware specs recommended by Autodesk for best performance.
Let me know if you have questions on the above.
Message 5 of 30
rui_es_pacheco
Performance lag is present only when Roombook is installed.
Now it is not (not installed). Revit performance is ok.
I use other addins. But they only were installed after confirmed the roombook causes that lag.
Is there a mail to send journal? what files do you need?
Thank you
Message 6 of 30
rui_es_pacheco
Roombook not installed and revit its ok.
Whem roombook is installed revit is laggy.
Now I have not roombook installed.
Can You help?
Message 7 of 30
Viveka_CD
Hi @rui_es_pacheco
Can you share a journal file with us to test further?
I can send you a private upload folder. Let me know.
Message 8 of 30
rui_es_pacheco
Ok, i’ll share,
Please tell me what files you need.
Message 9 of 30
Viveka_CD
Hi @rui_es_pacheco
Here is information on how to locate your journal file
Let me know if you have any other questions.
Let me know if you have uploaded your files.
Message 10 of 30
rui_es_pacheco
Hi
Here are the Journal Folder
Thank you
Message 11 of 30
Viveka_CD
Hi @rui_es_pacheco
Your issue in in progress. Thanks for sharing your files.
I will let you know if more information is required from our end.
Message 12 of 30
rui_es_pacheco
Are There some progress?
Tks.
Message 13 of 30
rui_es_pacheco
It there some progress? I have installed 2019 version of Revit and the plug in, and the problem persists.
Please help, its really anoying.
Message 14 of 30
Viveka_CD
Hi @rui_es_pacheco
Sorry to hear that the problem persists. Thanks for checking in.
Let me check back with the team and see if I have an update.
Thank you again for your patience while we are trying to identify what is causing this behavior.
Message 15 of 30
Viveka_CD
Hi @rui_es_pacheco
Here's an update from the team:
On parsing your journal, your Revit 2018 is not updated. You are on 2018.2 and you'll have to update to 2018.3.1 from your Autodesk Desktop App. Let me know if you have any questions on this.
Secondly, your graphics card configuration does not meet the requirement for Revit 2018 - It is not listed on the recommended hardware page. See HERE for more information
Thirdly, your physical memory is high - which contributes to the lag in Revit. If you have any other third party applications consider disabling then for improved performance. See steps in the article: Revit: Slow Performance
Please let me know if any of the above recommendations help resolve the issue and if your team is on the same build and update.
Message 16 of 30
rui_es_pacheco
Same issue with Revit 2019 and Roombook:
Change between view windows is laggy.
Tested with new windows 10 pro lastest version, clean installation, Revit clean.
With only revit, view change behave correctly. After install only Roombook addin, view change is laggy.
Only way to work with revit lag free is not to install Roombook.
All other plugins and addins work correctly and lag free.
I had cliped a screen cast with and without roombook.
Please help
Message 17 of 30
rui_es_pacheco
no good
Message 18 of 30
Viveka_CD
Hi @rui_es_pacheco
Apologies for the delay and Thanks for your patience while this issue is being investigated. Thanks for sharing the screencasts as well, I'll log this with development. The team is trying to identify what is causing this behavior.
Also, please share a recent journal for Revit 2019.
Please upload to the private folder link (I will send you one shortly)
Message 19 of 30
Viveka_CD
Hi @rui_es_pacheco
Thanks for uploading your journals.
I've also shared a collector utility with you.
  1. Download the Collector utility attached to this knowledge article and save it locally on the machine which you are experiencing the issue
  2. Unzip the downloaded file
  3. Read the short Readme file and run the collector
  4. Add the collected data together with the affected Revit project file(s) to your Technical Support case with Autodesk
Let me know if you have trouble accessing the folder and when you've done accessing the folder.
I look forward to hearing from you.
Message 20 of 30
Viveka_CD
Hi @rui_es_pacheco
Did you have a chance to upload your extracted files from the collector utility?
