Room Tags changing colors
1 REPLY 1
dariawerynska
908 Views, 1 Reply
Hello there 🙂
I have tagged the rooms in a multifamily building and I want to make a colored distinction between the types of the apartments (1-room, 2-room etc.). Is it even possible in Revit to make it automatized?
So that when I pick the parameter "2-room" it goes yellow, and "3-room" appears blue and so on.
Thanks!
1 REPLY 1
Kimtaurus
in reply to: dariawerynska
You can't automate the colour of the tag (maybe you can with Dynamo), but you could use a Colour Scheme for the rooms.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Forma Design Contest
Technology Administrators
