Room Tag
Room Tag
anuragkhati
Room Tag
anuragkhati
I have an issue related to Room Tag. Here I'm attaching the image marking the issue.
Here I have assigned a room tag in my plan but both room have different dimensions.
Alfredo_Medina
What is the "issue"? I see a room tag with dimensions, showing the shorter dimension first, then the longer. It looks correct in all cases. What do you mean by "both rooms have different dimensions"?
anuragkhati
Yes it shows shorter first but we usually write width first then length , so how do we do that it will take take width first
Alfredo_Medina
Probably you will need two types of the same tag. You can open the existing tag, do Save as... then switch the order of the labels, save and load into project. Then change the type of room tag as needed.
Reverse the labels in the tag family.
