Room tag with shared parameter not showing up
kreekie
Message 1 of 15
kreekie
Hello...I have a floor plan with room tags.  The project is using a shared parameter file with parameters "Quality", "Suitability" and "Utilization".  It is a project parameter and it does show up as a parameter on the room schedule.
When I add these 3 shared parameters to the room tag and load into the plan they do not show up.  I have checked that the family and project are using the same Shared parameter file.  Any ideas?
Replies (14)
Message 2 of 15
Did you also add the Shared Parameter as a Project Parameter assigned to Rooms Category?
If so, did you enter a value for it under the Room's Properties?
Message 3 of 15
kreekie
yes (and thanks for your reply)
Message 4 of 15
kreekie
and yes the parameters have values
Message 5 of 15
kreekie
when I select the label in the plan there is a "?" where the parameters should show up.  It is not editable like the other parameters in the label.
Message 6 of 15
constantin.stroescu
maybe you have Visibility or a Visibility Parameter unchecked into Project...
Constantin Stroescu
Message 7 of 15
Hmm. Okay.  Post file. Let's take a look at it.
Message 8 of 15
constantin.stroescu
Select the Room and in Properties allocate values ( text value ) to your parameters...
Constantin Stroescu
Message 9 of 15
Select a room, not a tag, in your project and look at its properties. Do you see the parameter that you added to the room tag label?
Message 10 of 15
kreekie
yes I do, under the Data category. I even tried to move it to another
category, no lcuk.
Message 11 of 15
The only explanation is the shared parameter for the label is not the same as the parameter added to Rooms category in the project. Let's show a screenshot of the parameter in the project from the Project parameter dialog.
Message 12 of 15
kreekie
I didn't think of that, but I checked it and it looks ok
Please type your reply above this line -##
Message 13 of 15
TripleM-Dev.net
category, no lcuk.
Data Category? you mean Rooms category under the Data group....
Select the room, can you see the values for the parameters in the properties panel....screenshot mayby
If you select the parameter(s) is the project parameters dialog is the "shared" option checked and the "Export" button grey, and the Rooms category checked...
Can you post the project (or transfer parameters to another project file with a room and the tag)
- Michel
Message 14 of 15
kreekie
I will post..I have to leave for a meeting but will surely follow up asap
Message 15 of 15
Same SP File, not same SP.  Is that it?
