Room Tag Visibility in Areas
1 REPLY 1
mdulaney
934 Views, 1 Reply
I'm using Revit 2015. I created an  Area plan (rentable) which is one view. In a floor plan view, LEVEL 01 - FLOOR PLAN, I added rooms and a room tag. In the Area plan the room reference is showing but not the room tag. In the visibility graphics the room tag is checked. In the Reveal Hidden Elements the room tag does not show but the room reference lines do show.
I then added a room and room tag to another room in the Area plan and the room tag shows. However, in the floor plan, the room tag does not show (doing the opposite of the above). In either option I am not using worksets or view templates so that is not part of the problem.
What is causing the room tags not to show when I go to another view? It is like they are toggling on and off but I can't find the toggle.
Mike D.
1 REPLY 1
mdulaney
in reply to: mdulaney
Never mind - answered my own question: Tags are view specific so they only show in the views where they were added (or if they are copied).
Forma Design Contest
