Hey everybody, I have a question. Although I have a Room Tag as you can see the right side, there is another tag in my plan. So do you guys have any idea about it ?
Is the one on the right the tag in the family editor and the one on the left how it looks on a room?
If so are there visibilility parameters on the tag which are controlling how much it shows?
Two things I can think of. EITHER you have two different types of Room tag loaded in your project OR Base/Wall/Ceiling finishes have not yet been assigned to that room so it's not reflecting.
If this resolves your issue, please click ACCEPT AS SOLUTION to enhance the forum.
I always create a Room Schedule in conjunction with placing Rooms and Tags. It helps in troubleshooting issues such as this.
I can not believe that I did this mistake . Sometimes I have this kind of problems, as you say so, the information for room has not been assigned so it does not reflect . Thank you for your all information...
