correct me if i'm wrong but if you edit a group and an element is no longer needed, best practice is to Remove the item from the group first and then deleting it. if an object is deleted, it will cause issues with other groups of the same name causing revit to think that the object has been excluded and unable to restore.
...also, never introduce a new element into the Project while inside Group Edit Mode. That is, don't load a new family, create a new family Type, or Model In-Place a new element while in Editing Mode. Always ADD or REMOVE existing elements.
thats probably where I went wrong. I added sweeps (wall base trims) while in group edit mode. Then at some point in time, I deleted a said sweep in group edit mode.
said sweep is still visible when the group is selected (ghosted).
any possible to remove or bring it back WITHOUT ungrouping?
Why don't you create a new Wall Type with an integrated sweep, and then Edit Group to swap out Wall Types?
...just to clarify, are you just wanting to add a Wall Sweep to a Wall inside Group Edit Mode. That shouldn't be problematic. Are you saying it is?
@barthbradley wrote:Why don't you create a new Wall Type with an integrated sweep, and then Edit Group to swap out Wall Types?
right now, just want to remove the ghost sweep.
next time, I will add the sweep and then bring it into the group.
OK. I added light fixtures to the RCP plan (not in a group). Once I have them in the correction location, I then attempt to add them to a group. I ONLY selected the light fixtures and now I'm getting 4 warnings about a specialty equipment that is not even visible in the plan. talks about "identical instances....."
@ToanDN yes, all the light fixtures are ceiling hosted. once I have them "centered", I then edited the group and Added them by selecting each fixture ( @barthbradley ). note that the specialty equipment that I got the warnings on were shelf and rod family.
@barthbradley no. just kept it under the group editing errors, etc.
***edit*** noticed that when I went back to look at the Shelf and Rod family, they were placed on the face of the wall. I removed them and added them back as placement: Work Plane. that fixed the error/warnings.
That confuses the heck out of me. Were you saying that adding new light to the group gave warnings about some shelf and rod? Does add anything to the group give same warnings? It seems like the warnings are always there, they just sit tight and wait for you modifying the group to pop up.
@ToanDN wrote:That confuses the heck out of me. Were you saying that adding new light to the group gave warnings about some shelf and rod? Does add anything to the group give same warnings? It seems like the warnings are always there, they just sit tight and wait for you modifying the group to pop up.
confused me too. yes. no. who knows.
got another question with regards to editing groups. when editing a group, if all the similar groups are locked, does this affect items being added/remove and/or moved around?
