Room Tag Leader Bug
Room Tag Leader Bug
Room Tag Leader Bug
I am writing this post to make autodesk aware of a bug. I am running 2018.2 and when in a section view using a leader line with leader end "filled dot 1mm) It appears like it is on an oblique face. I have attached a photo. If fellow users think I should post this in another section of the forums please let me know.
If we are on the topic of room tags and leaders, could Autodesk please add the same concept of "snapping leader lines" that are present in text. Like it snaps to 90 degrees, or straight
I can't replicate.
Want to post your file?
Regarding your second question: We have "Angular Dimension Snap Increments" under Snaps on the Manage Tab.
Thanks for the quick reply. i have a dummy project with the same template attached if you wanna take a look. However I think I solved it.
For the appearance of the 1mm head leader. I first tag the room, then check the box for leader, then drag it to outside of the room. The leader head appears funny like shown before. But after I adjust the elbow the leader head appears normally.
The same goes for my second question actually. If I keep the leader line straight and try to snap to 90 or 180 it wont allow me to..... But if i first adjust the elbow to any angle then snap back to straight it will snap to the 90, and 180 degrees I am looking for.
ctreat
Did this ever get resolved? Still have this issue.
