Yep, just another day where Revit is doing absolutely weird, inexplicable s&*t again, burning up more time trouble-shooting and finding work arounds...
In Section Views, all of the existing views I've been using since starting the project, when I tag a room and then select "leader" so I can drag the tag outside of the building, the arrow, which is set to a filled dot, appears to viewed at an angle. It doesn't appear as a perfectly round circle, it appears as an oval. In plan views, the arrow dot looks like it should - a circle. Different rooms using the same tag in the same view have the arrow skewed to different degrees.
My section views are parallel/perpendicular to the building walls. Everything is orthogonal.
This is happening only in existing views that I have be using since starting the project. If I create a new section, either orthogonal or at a random skewed angle, and tag a room w/ the same tag family and arrow, the arrow shows as a circle. Am I doing something wrong again that I'm not aware of?
