room tag leader arrow skewed in section view
mpukas
Message 1 of 17
mpukas
Yep, just another day where Revit is doing absolutely weird, inexplicable s&*t again, burning up more time  trouble-shooting and finding work arounds...
In Section Views, all of the existing views I've been using since starting the project, when I tag a room and then select "leader" so I can drag the tag outside of the building, the arrow, which is set to a filled dot, appears to viewed at an angle. It doesn't appear as a perfectly round circle, it appears as an oval. In plan views, the arrow dot looks like it should - a circle. Different rooms using the same tag in the same view have the arrow skewed to different degrees.
My section views are parallel/perpendicular to the building walls. Everything is orthogonal.
This is happening only in existing views that I have be using since starting the project. If I create a new section, either orthogonal or at a random skewed angle, and tag a room w/ the same tag family and arrow, the arrow shows as a circle. Am I doing something wrong again that I'm not aware of?
Replies (16)
Message 2 of 17
Weird.  Post the file.
Message 3 of 17
mpukas
Will do - pls tell me again how to attach a file larger than the allowable size? DropBox link?
Message 4 of 17
can you not ZIP it and attach it?
Message 5 of 17
mpukas
it's too big when compressed, and I've found .rvt files don't compress much. From 160mb to 155mb. I made a copy, purged, removed links and images.
Message 6 of 17
Well, I'm seeing what you're seeing. Some weird sh*t for sure.  I don't have a clue what's going on. You stumped me.
@ToanDN?  You out there?
Message 7 of 17
Look okay here.  Which views have the problem?
Message 8 of 17
EAST-WEST SECTION 2
Message 9 of 17
When I placed a new tag it looks okay.
Message 10 of 17
Yeah, I know that. So, what are you suggesting? That the OP go through every view and redo them.  C'mon man!
Message 11 of 17
@mpukas: I'd open up a Support Case and I'd submit this SH*T! to Autodesk.
Message 12 of 17
You can add an elbow to the leader to fix the arrow shape.
Message 13 of 17
mpukas
Adjusting the elbow works for me now, and I can put the leader back to straight and the arrow stays true. Thx again TaonDN.
Still, another weird Thing That Should Not Be in Revit. It's a never ending slurry of this kind of crap for me... maybe not always on a daily basis, but at least a few times a week.
Message 14 of 17
C'mon! That's not a solution! To go to every single view and modify annotative elements that were just fine the day before!  WTF! I'd raise more of a stink about this personally.  I'd be on the horn to Autodesk in a heartbeat.
Message 15 of 17
mpukas
To be clear, the tags themselves were not changing. It's placing a new room tag w/ a leader in an existing section view that I have the problem, and still do. If I bend the elbow the arrow appears correctly, and then I can straighten the leader. When I create a new section view and place a new room tag w/ leader, the leader arrow appear just fine the first time.
I agree that ToanDN's solution is not an acceptable solution, it's a work-around to a problem THAT SHOULD NOT BE.
Also to add, I started this project w/ a brand new template file that I had just created. I figured it was time to start from scratch, so I started a new template file f/ OOTB and imported/copied my standards into it. I was having random weird problems in older projects, and I still have random weird problems in new projects started with the new template.
Message 16 of 17
What are your screen resolution and display scaling?
Message 17 of 17
mpukas
1600x1200 100%
Never have seen this problem before, and using the same monitor since I started Revit nearly 7 years ago - Dell Ultrasharp U3014 30"
Type a product name
