In Revit, when moving a room, the normal behavior is for Revit to display the following warning indicating the correspondent Room Tags in all the views where the relocated room is tagged are outside of the room:
The warning gives you the option of clicking OK, which makes all the room tags (in all the views where the room is tagged) move to the center of the room in question.
You have the option of clicking Cancel and all the tags will remain outside of the room and become orphaned (displaying no room information). You will need to select the tags and activate the leader for the tag to display the room information.
We recently noticed that in the most recent update of Revit 2023 the behavior has changed:
When moving a room, the Room Tag will remain outside of the room, and automatically a leader will be activated. To move the room tag back to the room, you need to select the room tag and deactivate the leader. You need to do this on every view where the room is tagged.
We contacted Autodesk, and the response we received from an Autodesk expert was: “I believe this is a new addition to Revit 2023 and was extracted from the Revit Ideas forum for implementation”.
I would like to confirm this change was in response to a request from the Revit Ideas Forum.
As part of the workflow when planning and revising layouts in Revit and as a consequence the rooms are moving around the floor plans, we have always asked Revit users to choose the “Move to Room” option to make sure all Room Tags are moved to the room location through all the Floor and Ceiling plans views in the Revit Model.
We work in large projects with thousands of rooms and hundreds of views where major planning revisions take place every day.
I would like to hear your opinion and if you have any suggestions or comments. I may be missing something here, but I see this will create additional work for cleaning annotation through all views in a project. I wish there was an option to control how you would like the room tag to behave. Thank you.
