Room separation line isn't visible when copied
I have an issue with room separations in a design option.
I have a plan view with a design option assigned to it. It has a series of room separation lines defining rooms. When I use the RSL tool to draw a new line, or create similar to create a room separation line, the line is visible in the option. When I copy the RSL in the view, it becomes invisible in that view only.
When I draw or copy the RSL in 'main model' it shows up fine.
Is this a known issue? Could this be something in the view template? What am I missing?
Thanks!
cbcarch
check here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Thanks, but still no luck.
This issue just popped up on another project, this time without the help of design options. In that project, the same view template was applied to two separate levels. On one level, the RSLs showed up fine. On the other level, it did not.
cbcarch
-Any Filters in the view?
-Workset turned off/ RSL on wrong workset?
-Phasing problem/RSL on wrong Phase? View Phase Filter set wrong?
-Color Scheme set to Foreground?
-Masking/Filled regions?
-Did you try using Reveal Hidden Elements?
-Try turning View Template off (set to none), then turn everything on in the view.
Cliff B. Collins
Tried all of the above. There is already another RSL visible. If I copy it, it is now only visible in 3D or different plan views. May be a bug.
cbcarch
Does this happen in just one project?
Try creating a new test Project, and see if it happens.
Cliff B. Collins
I could not recreate within a new file, so that makes me think it was something specific to that view or file.
