Room not showing in plan
TeresaXMJLQ
Message 1 of 18
TeresaXMJLQ
Room Food Storage is showing up on the RCP but not on the floor plan. I do not have any plan regions in the area. If I try to tag the floor plan I get a message it is already there and will be duplicated.
Any ideas?
Replies (17)
Message 2 of 18
syman2000
Have you change the room height? Also check and see if the room isn't hidden by element accidently or misplaced in the wrong workset.
Message 3 of 18
TeresaXMJLQ
Yes and Yes, it is not hidden either.
Thanks for you ideas though-
Message 4 of 18
Can you select that room on the RCP and show its properties here?
Message 5 of 18
TeresaXMJLQ
yes
Message 6 of 18
@TeresaXMJLQ wrote:
yes
It is not a yes or no question 😉
Message 7 of 18
TeresaXMJLQ
Attached is the properties
Message 8 of 18
What if you change the Computational Height of the Level from 3'-0" to 0?
Can you cut a section, turn of Room Interior Fill for the section view and see what you get?
Message 9 of 18
TeresaXMJLQ
I cant its greyed out
Message 10 of 18
You change Room Computational height but opening a Section or Elevation, select the Level and change from its properties.
Message 11 of 18
TeresaXMJLQ
Nothing shows up in the Floor Plan view still.
Message 12 of 18
Can you share the model here?
Message 13 of 18
TeresaXMJLQ
No sorry~
Message 14 of 18
syman2000
Is your room set to volume?
Message 15 of 18
TeresaXMJLQ
It is set to Areas Only. This is the message I get when I try to tag the room.
Message 16 of 18
syman2000
Cut the section. As well move the room away from the stair opening.
Message 17 of 18
TeresaXMJLQ
for goodness sakes lol, Thanks~! I moved it away from the stair and added a room separation line and that fixed it.
Thanks for spending so much time helping me figure this out!
Message 18 of 18
Does the room show if you create Plan View from scratch (View > Plan Views > Floor Plan > Uncheck Do not Duplicate...)?   If so, turn on Plan Region and delete any on the Plan view that the room is not showing.
