Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Room Not coming up properly
j.sisodia
j.sisodia
Hi all, We have been struggling with these room corners, the only option that we have is to use room separation lines, I was wondering if anyone has come across similar issues and have a better way to deal with these?
Simon_Weel
Looks like an element is not Room-Bounding. If it is but Revit still insists it isn't, then use a separation line. You can spend hours trying to find out why Revit is doing what's it doing, but that's mostly a waste of time...
handjonathan
Hi @j.sisodia
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Simon_Weel helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
j.sisodia
thanks for your reply. yes, we could only figure it out by room separation lines.
j.sisodia
yes, by using a room separation line, but it's a lot frustrating as it will generate a lot of warnings.
