Cuts Geometry tool
Cuts Geometry tool
NoyAFKWU
Cuts Geometry tool
NoyAFKWU
I'm encountering an issue with the Cuts Geometry tool. Despite removing the checkbox, the wall remains cut. Has anyone experienced this problem before, and if so, how did you resolve it? Any insights or troubleshooting tips would be greatly appreciated!
joshua.maginskyKKXQ3
Can you confirm if the issue persists after the following
Open the Family Editor > Modify > Geometry > Cut drop-down > Uncut Geometry
handjonathan
Hi @NoyAFKWU
Thanks a lot for posting your question to the forums!   Has the solution suggested by @joshua.maginskyKKXQ3 helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
NoyAFKWU
I'm trying to assign a parameter that controls if the wall is cut or uncut.
when I use uncut geometry tool the void is useless and when I cut the geometry it stay cut no matter what I do
SteveKStafford
A void "remembers" a cut relationship with solid so the trick to turning on/off a void is to "push/pull" the extent of the void so you push the void into the solid to cut and pull it back when you want to turn it off. See the attached mock up in Revit 2024 family.
Keep in mind that you can't use a void to cut the wall AND use an opening which the way the templates are configured. You'll need to use a void for the window opening too, like in the mock up.
Steve Stafford
