Room Not coming up properly
j.sisodia
j.sisodia
Hi all, We have been struggling with these room corners, the only option that we have is to use room separation lines, I was wondering if anyone has come across similar issues and have a better way to deal with these?
Simon_Weel
Looks like an element is not Room-Bounding. If it is but Revit still insists it isn't, then use a separation line. You can spend hours trying to find out why Revit is doing what's it doing, but that's mostly a waste of time...
handjonathan
Hi @j.sisodia
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Simon_Weel helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
j.sisodia
thanks for your reply. yes, we could only figure it out by room separation lines.
j.sisodia
yes, by using a room separation line, but it's a lot frustrating as it will generate a lot of warnings.
