Room Grid Lines
Room Grid Lines
Nick_LopezF8J5Y
Room Grid Lines
Nick_LopezF8J5Y
Hi everyone, as a newcomer to REVIT, I am curious as to how I can get rid of these gridlines? They are only visible in the rooms when I zoom in. When I zoom out, they are not visible. Any advice would be appreciated, thank you!
ralphdenhaan
Seems you are using an Area Plan view?
try the visibility/graphics setting (shortcut: vv)
turn of the color fill for Area/Room.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nick_LopezF8J5Y
No Sir, I'm in the floor plan, specifically level 1, view.  I just zoomed in on a specific room area. I attached other photos to give you a better picture. I attempted your solution and didn't see a change. The "3" image shows the ceiling plan. The way the lines show in here I actually prefer. Not sure how I can edit them in general though. Thank you for your support in advance.
ralphdenhaan
Ah,
Then it must be your material pattern from the Ceiling.
Same solution but then turn off ceilings.
Or change your model pattern:
Turn off Room Color Fill.
