Room dimensions
Room dimensions
glkirk
Message 1 of 14
Room dimensions
glkirk
Can Revit produce the name of a room and the two interior dimensions of that room.
I know it can produce the sq. ft. of the individual rooms but can it do this           BEDROOM
        13'-6" X 13'-2"
Replies (13)
Message 2 of 14
Sure.
Message 3 of 14
glkirk
Ok, thats interesting !
But before I get into it, I wonder how it handles rooms that are not square or rectangular.  Say, that has a 2' deep closet along more or less than half the length of a wall?
Are there any hidden tricks to come up with you have done here?
Thanks!
Message 4 of 14
Message 5 of 14
hmunsell
I saw the image and was wondering how you did that. that's a nice formula in the room tag. 🙂
Howard Munsell
Message 6 of 14
For irregular spaces AutoCAD Architecture reports the LxW size of the smallest bounding box which would enclose the space. Be cool if Revit could match this as all the formula based tags I have found fail when the room is not regular
Message 7 of 14
glkirk
How does one set up the L&W tag please?
Message 8 of 14
glkirk
Bump please
Message 9 of 14
martijn_pater
You can download tag in reply #2 to see... ? it's just LxW in label? edit: see calculated values
Message 10 of 14
How the 'dumb' BIM product handles space dimensions (attached as forum error was blocking image upload when I tried). Useful for our flooring contractors as they can get max l/w from the room tags even if the space is not explicitly  dimensioned (as added to this plan to show where dims come from). Have not yet been able to match this in Revit as the perimeter/ formulas fall apart with irregular rooms
Message 11 of 14
glkirk
Thank you
Message 12 of 14
martijn_pater
Ofcourse, np. It's calculated values in a label, see attached.
Message 13 of 14
akshay_dagwaleJF8VN
Community Visitor
Community Visitor
how to add in  room schedule in this parameter l and w getting error
Message 14 of 14
mhiserZFHXS
Well its telling you one error right there. Parameter names are case-sensitive. You typed in "perimeter". The P is capitalized in the actual parameter. "Perimeter". Not saying this is the only issue, but its certainly one.
