Room Color Scheme doesn't work on groups.
Message 1 of 10
Hello There, I have a set of groups and I am assigning rooms to them but when I try to use a color scheme then it doesn't show the colors. if I add a room out of the groups, then the colors are displayed, but with the group it doesn't work. Is there a way to solve it?
Replies (9)
Message 2 of 10
Rooms in Groups should show color.
All Group Instances in View:
Message 3 of 10
cbcarch
Check:
Phasing?
Room separation lines?
Design Options?
Linked model? (room bounding, does it have rooms in it?, etc.)
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 4 of 10
Did you assign a value of the Room parameter drives the Color scheme to the room in the group?
Message 5 of 10
Well, they aren't being displayed. If I select the group then I can see the colors, but only when it's selected.
Message 6 of 10
Everything is ok. the problem is in the group. if I assign a room outside the group then it works. If I select the group where the rooms are created, then It shows the colors.
Message 7 of 10
No, I just created a group and placed a room inside it. Then when I add a color scheme then it doesn't display the colors.
Message 8 of 10
Are you sure that you "can see the colors...when [the Group] is selected"?  I find this odd, since I can't. When I select a room Group, the highlights a bluish transparent tint, making it impossible to discern any color.   Are you sure you have a Color Scheme associated to the View?  Room Color Fill Subcategory checked?
Message 9 of 10
this is when selectedthis is when selectednotice it doesn't show the colorsnotice it doesn't show the colorsodd indeed, I don't understand why it happens. There are many elements, and if I ungroup them ( so the colors be displayed, 'cause it works normally outside of the group) I will have to deal with all those elements separately
Message 10 of 10
Can you post an RVT for us to see?
