Room boundary problem
4 REPLIES 4
mirceaatbowtie
321 Views, 4 Replies
Hello everyone,
I am going bonkers as I do not know why my room does not extend to the west side to the sliding door.
I have attached the file here for reference. I cant make my model under 71mb so I need to post a download link
https://bowtieconstruction86.sharepoint.com/:f:/s/BowTieConstruction/EiXwToS3c59NqbNg4-cxDWQBmQABxBj...
4 REPLIES 4
rxi.gg
in reply to: mirceaatbowtie
Thats crazy I can't find anything that make that happen. You have several phases... did you check all of them?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
I have done the following to fix it:
- Set the Room Computation to Area+Volume
- Add a room separation line
There are several issues I would raise but I did not fix since I don't know the history of the project:
- There is a wall created and demolished under New Construction. Is is a temporary elements?
- I would add a new level where your new floor is, and create floor /ceiling plan associated with this new level, instead of an existing level with a negative offset.
I guarantee you that it is associated to one or more of those Warnings. You have a ton of them!   I would strongly recommend doing some routine maintenance. Resolve as many of those Warnings as you can.  Might be too late now to resolve some.  It happens.  Warnings sometimes can't be resolved unless other Warnings are resolved first - and those Warnings may be undiscoverable.
@ToanDN thank you very much for the process I managed to fix it. Very useful indeed.
@barthbradleyCan you recommend a process of routine maintenance? I am trying to build some standards as we go along and maintenance seems to be at the bottom of the priority list . At what intervals should it be done and what are the elements that need to be cleaned ?
Forma Design Contest
Technology Administrators
