Roofs - clean up Gable to Shed intersection
Redrunner92
Message 1 of 9
Redrunner92
Is there a tidy way to make this intersection of a gable and shed roof? I do not want the extra eave which continues under the shed roof. See the image below for details. I have attached a simplified version of the file here for further investigation. I would appreciate a detailed explanation so I may follow the steps anyone may suggest.
Replies (8)
Message 2 of 9
I like it. Your roofs have different plate heights. It's a good solution. I mean you could do this, but I wouldn't:
Message 3 of 9
Message 4 of 9
Message 5 of 9
Redrunner92
Regardless of what I would like to do, the client does not want different plate heights, at least not in the images for this early design stage.
Message 6 of 9
Redrunner92
Nifty. I had not used slope arrows directly beside and parallel to sketch lines with a defined slope. Thank you for showing me this.
Message 7 of 9
You are the one who put the two roofs at different Plate Heights. Not me. In fact, I wouldn't have because it would have created the very condition you were trying to solve for.   But, I figured there was a good reason for the over-framing.  If so, then what you come up with (e.g. the fascia return under eave) was pretty nice.  Pretty common  too.  I see it everyday.
Message 8 of 9
Oh, and by the way: you are welcome.
Message 9 of 9
"the client does not want different plate heights"?  Well, that a nugget of information. Maybe you should have mentioned that up front.  A little late now.
