Roof various issues
Roof various issues
Marie.j03
Roof various issues
Marie.j03
Hi community,
I have 2 questioons about roof tools.
1) How do I change the Facia thickness an height? If I select it there are no options to change dimensions
2) I am not able to understand how the roof sofit tool work can someone please how it works?
MJ
Mrci bcp
Accepted solutions (3)
RDAOU
@Marie.j03
Facia tool is profile based. The dimensions are driven by the parameters given in the profile used. Go to type properties and check which profile you are using, then in the project browser>>families>>profiles,
  • either duplicate to create a new type of that profile and change its dimensions
  • Or model a new profile with the necessary parameters, load into the model and use that instead
Marie.j03
Sorry. I am not sure how I missed it. I was expecting something more like beams with b and h and didnot notice it is the same as sweeps and slab edge.
Ad the soffit sltp can you please help on this? It seem to create like a floor or roof so I am not sure if I am using it right
RDAOU
@Marie.j03
Apologies I missed that part.
In principle it does create a roof but without the defined slope option. You need to pick roof edges as well as the wall edges.
Ie: its  the same steps one would use to create a ceiling or a floor with an opening using the sketch lines rather than the opening tool or a hosted void family.
Alternatives
  • You could also use a ceiling element or a floor element (similar to roofs but at times may be more convenient and better for hosting purposes).
  • Sloped glazing
  • pattern based ccomponents on a divided surface
  • Beam system
Marie.j03
The command exit after this error and does not give the option like before to change workplane. How can I reset it
RDAOU
Simply go to Architecture tab >> Work Plane pan and set it to a Level datum. Once you set that and start the roof soffit tool, you see the usual options like before including draw tools, set Work Plane and the options to toggle between boundary lines and slope arrow
Otherwise place the soffit on a plan view instead (assuming that you haven't changed the work plane in that view too)
Marie.j03
Merci bcp that worked perfectly. Thank you very much for your kind help.
MJ
