Roof Soffit/Facia Boxed End
BigPicture045
Message 1 of 9
BigPicture045
What is the best practice for making the following roof soffit detail? Please see the reference image below:
Would you use only roof soffit and facia? You can see that the soffit / facia create kind of a box out at the end. I've been having difficulty creating this shape and have been making a mess with facia. Looking for some pointers. The image below is what I have so far.
UPDATE:
I've gotten really close, however, I am still unsure how to model facia going vertical. You can see that this is still the piece I am missing.
Replies (8)
Message 2 of 9
I usually model porkchops in-place.  FWIW.
Message 3 of 9
Model the wall trim as an in-place sweep.
Message 4 of 9
Message 5 of 9
BigPicture045
Thanks @ToanDN That will work.
@barthbradley I was thinking about using walls to model the feature. I would like to have the walls join together so that the connections are made at corners, but I would like the walls to not join to any other walls than themselves. Do you know how I can modify a wall so that it will not join any other walls besides itself?
Message 6 of 9
Hard to visualize what you are describing, but disallow join is how you disable auto join. You can still join them individually by using Join Geometry tool.
Message 7 of 9
Model the walls with Join Status = Disallow then manual Join Geometry them.
Message 8 of 9
BigPicture045
@ToanDN
How do I model in place sweep under an angled roof as in the picture below? I would like to add trim around the roof against the wall of this gas fireplace outlet. Is in place sweep only a horizontal / vertical tool?
Message 9 of 9
Model in -place, Pick path, and pick the bottom lines of the roof and soffit.
