Roof: Sloped in sloped Support
17 REPLIES 17
Message 1 of 18
XXalessio.amodioXX
1734 Views, 17 Replies
XXalessio.amodioXX
Hi all,
I have to model such a roof.
The roof is supported by sloped precast roof beam. I try to model the elements of the roof separatelly with no success.
If I apply a variable layer i cannot apply any sloped arrow and Vice versa. Any idea?
Hi all,
17 REPLIES 17
Message 2 of 18
manuelmunoz87
I'm not sure I completely understand the drawing, but have you tried drawing it as a flat slab and then using the 'Modify Sub Elements' tool? You can use this tool in conjunction with a variable layer too
After you click on the tool, you can assign a different height for each of the sub elements (vertices and sides) in your slab. You can also add additional vertices and lines to create the shape you're looking for
Message 3 of 18
XXalessio.amodioXX
Yes I tried. Unfortunately Bottom side of roof remain Flat. My roof is laying on sloped precast beams.
Message 4 of 18
martijn_pater
Draw it as two roofs using modify subelements and join geometry.
Message 5 of 18
XXalessio.amodioXX
Hi.
I want to achieve a roof such that.
Inclination of the roof 5% on Sloped roof beam 2%.
Imagine simple roof.
Any idea?
Hi.
Any idea?
Message 6 of 18
Do you have elevations figured out for all these points circled in red?
Message 7 of 18
Also, the overall retangular dimensions of the footprint?
Message 8 of 18
uncheck "Variable" in the Roof Assembly if you don't what the Roof to remain flat on the bottom when using Modify Sub Elements.
Message 9 of 18
XXalessio.amodioXX
Hi
main part shold look like this.
Hi
Message 10 of 18
That elevation view doesn't give any useful information. You need to figure out the elevations of each of those red-circled points shown on your Roof Plan.  That's going to require drawing angled Ref. Planes/Lines in the different views to find out where they intersect (that's the red-circled points on the Roof Plan) -- and then measure the intersections' heights above zero origin.  Those elevations calculated are what you enter for the elevation values of those Points I've circled in red on your Roof Plan.
Message 11 of 18
2 shape-edited variable-thickness roofs stacked and joined:
Message 12 of 18
in reply to: barthbradley
Message 13 of 18
martijn_pater
...hmm just curious why? Wouldn't it be much simpler(/cheaper) to put the beam at 5% slope...?
edit: think I misinterpreted, so actually you're talking about a beam and a roof... so you have to use just one roof with variable set and then use a void cut on the bottom to slope it at 2%...or two roofs if one is a structural deck.
Message 14 of 18
I kind of get why. Look at the OP's Roof Plan. He's got a mess of opposing slopes aimed towards drainage inlets he's building into the structure.  Still, it's hard to visualize the construct. Don't know what the slopes are supposed to be, or what the actual dimensions are.
Message 15 of 18
martijn_pater
...interestingly enough, when you join a structural deck floor with another floor/roof with modified subelements the section material disappears. Got it to show by giving the structural deck a 1mm offset (cantilever), not sure why it does that... suppose the cannelures are rotated the other way also, but it seems that's a little tricky aswell with the cut pattern/material...
sloped roofs with joined geometrysloped roofs with joined geometry
Message 16 of 18
in reply to: XXalessio.amodioXX
See attached.
See attached.
Message 17 of 18
martijn_pater
in reply to: ToanDN
martijn_pater
... that works, same issue with the cut pattern though. So if you offset it 1-2mm in the sketch ie. that will work.
Message 18 of 18
XXalessio.amodioXX
I want to thank you all for the effort and preciuous information.
The roof will be a Green Roof supported as you well intended by a trapezoidal sheet.
The TR will lay on Precast beam and the 5% slope (Main part) will be provided by Insulation.
Just trying to find the easiest and best solution.
EDIT
In differetn project this was designed by joining more layers.
It is a good solution but problematic if someone mistakenly unjoin geometry. The volumes will overlpa
EDIT
