1. Did you try to erase all segments and start from the begining?
yes, but it didtn't work...
2. If yes, then do you make the fascia as one, or you stop, then start the
command again and wait for them to join?
I've tried that too, but it didtn't work again...
Do you use add/remove segments?
Yes, but it didtn't work...
the problem happens when we try to place fascia in roof that just have 2
slopes!!
But, obviously, this is possible in real construction....so I can't
understand why it's not possible in revit!!
