Roof Plan-Gable issue
mmward
Message 1 of 10
mmward
I am replicating an AutoCad drawing into Revit, and I am running into problems regarding the roof. There is a large gable on the rear of the house, but Revit is not allowing me to create this. I have attached the desired elevation, roof plan, and my current situation in Revit.
Replies (9)
Message 2 of 10
Post the DWG.
Message 3 of 10
mmward
Attached are the elevations with roof plan.
Message 4 of 10
what about the Roof Plan too?
Message 5 of 10
mmward
It's all in the same file.
Message 6 of 10
afraid not.
Message 7 of 10
mmward
Let's try that again...
Message 8 of 10
You can get there (for the most part) by using Slope Arrows.
Create a Roof Slope Using Slope Arrows | Revit LT | Autodesk Knowledge Network
Message 9 of 10
mmward
Got it!! Thanks so much for the advice. The roof was still extending below the roof level, but realized I needed to change the "plate offset from base" in a couple of places to make it work.
Message 10 of 10
carlusremod
The Owner Dashboard is a personalized view of your home and suggests you stats like how many humans are viewing your list, gives you easy access to edit your property records, and more.
