Roof openings
Roof openings
Darwin33
Message 1 of 12
Roof openings
Darwin33
I have a roof where there are some openings for dormers. The thing is that i need to edit those openings, but as far as I am looking for the elements that have created that openings I do not find them. There is no 3d void models that cut the geometry neither no built in cuts. What I am missing? In the pic you can see some 3d voids, but no one of them is cuting or interfering the geometry. How can i found how where the openings made?
Thank you
Replies (11)
Message 2 of 12
You aren't missing anything. You can't edit a Dormer Opening. If the Dormer Opening is impeding you, then don't use a Dormer Opening. Cut the opening via another method.  There are a bunch of other ways.
Message 3 of 12
What you are showing in your screenshot is not a Dormer Opening.  A Dormer Opening is a closed-looped sketch boundary. Best way to find it would be to do a crossing-window selection of the whole area and look for it in the Filter Dialog Box.
Message 4 of 12
Darwin33
I have double checked and you are right, it is not a dormer cut. Also the only void elements are those shown. None of those made this cut. Any other idea of how to cut the roof?
Message 5 of 12
Maybe a Mass. Turn on Mass Category and press Show Masses and Forms on the Massing & Site Tab.
Maybe an In-Place Component. A Void Extrusion attached to the Roof.
Have tried using Reveal Hidden Elements?
Message 6 of 12
Post the file here and I'll take a look at it.
Message 7 of 12
constantin.stroescu
maybe the hole is made simple  by Edit Footprint of the main roof, as shown in my screencast:
(view in My Videos)
Constantin Stroescu
Message 8 of 12
Darwin33
Yes I have tried to reveal hidden components and no luck. Is it possible the other way workaround, select the roof as host and then look for hosted elements?
Message 9 of 12
Darwin33
Thank you for the video, but when I edit the roof I only can see the complete perimter, no hole on it.
Vielen dank
Message 10 of 12
Post the file.
Message 11 of 12
constantin.stroescu
what about a Void Family that cuts the Roof?
(view in My Videos)
Constantin Stroescu
Message 12 of 12
Darwin33
Thank you for the offer, but it is a firm project so I can not upload it.
Finally I ve found how was cut. It was cut by a slanted wall. The thing is that the wall worked as a void element, ie invisible. I never thought that you could use wall to cut elements and turn that walls like invisible as if where voids.
How can you made a wall invisible?
Also when you have an element cut is it possible to identify automatically which element is cuting it. Because it took me long time to indetify this wall.
I post the screenshot with the wall in blue.
Thank you for your help.
