Nosing on staircase - flush to tread and riser but different material
1 ANTWORT 1
Nachricht 1 von 2
kristjanayr1
159 Aufrufe, 1 Antwort
Could anyone advice me on how I could make these nosings on my staircase in revit?
Different material and with steel nosing strips, and I need it to be flush to the tread and the riser material.
Also it doesn't go all the way to the end, will need to leave gaps as seen on the sketch.
Thanks in advance!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: kristjanayr1
You can model that edge treatment as a Baluster in a Rail -- that's if you REALLY need to model it.  Frankly, I would show that sort of thing in Construction Details.
Re: custome tread and riser in revit stairs - Autodesk Community - Revit Products
