Roof not cut in section
davidefranco92
davidefranco92
Does anyone know why all of a sudden in some Sections my Roof is not cutted anymore?
(In the cross section as you can see, it works properly)
Hard to tell without the model.
TripleM-Dev.net
Hi @davidefranco92 ,
Planregion in view maybe, because part of cutpattern is visible.
Can you share model (or that part of the model)?
- Michel
davidefranco92
It's always hard to share the model, because it's a work of the office and I don't have the rights. Can I maybe share via PM?
@ToanDN @TripleM-Dev.net
davidefranco92
Also, as you can see in the image attached, the roof is not being cut from the 3D cutbox either!
miza_aalmacin
I've come to learn that the solution to most problems associated with random objects missing for no reason is "Phasing". Mess around with your phase filter until everything is showing up.
