Roof modelling
Roof modelling
tegorovaB77X2
Message 1 of 17
Roof modelling
tegorovaB77X2
Hi everyone,
I tried to solve this roof in Revit and have a problem with how to approach highlighted spots. Jog in center and roof saddle on the right. Attaching a screenshot from Autocad and another one from what I have in Revit. Will greatly appreciate your advice. Thank you
Replies (16)
Message 2 of 17
Separate roofs at higher plate heights joined to main roof via Join Roof Tool.
Post the DWG and/or RVT.  We can show you how to approach.
...If that suggestion of mine is nowhere near what you are talking about - which just might be the case - definitely post the file or a fuller explanation.
Message 3 of 17
This what you are after?
ONE Roof using "Offset From Roof Base" method.
Message 4 of 17
tegorovaB77X2
Thant's right: Separate roofs at higher plate heights joined to main roof via Join Roof Tool.
But when I try to join with roof joint tool it doesn't let me
Message 5 of 17
I don't why it's failing - unless the roof is missing/overshooting the target.
Post the file. Let's take a look.
Message 6 of 17
tegorovaB77X2
here is the file, hopefully it will give better presentation of the problem. Thank you
Message 7 of 17
tegorovaB77X2
3/12 slope everywhere
Message 8 of 17
Take a look at this one and see how I did the roofs in one roof using Offset from Roof Base method.
Message 9 of 17
tegorovaB77X2
Wow that is exactly what I need! What an amazing help. I didn't know I can create it with one roof method and offset. Thank you!
Message 10 of 17
You're welcome.
Did you figure out how it was done? How the magic happens?  It's not readily apparent. Edit roof sketch and note the very, very short line segments (no define slope on them) that connect all the offset roofs to the main roof.
Good luck. Catch you later.
Message 11 of 17
tegorovaB77X2
Thank you for bringing to my attention those little lines, I didn't notice them right away and it was affecting the result! also, I did get an error message after clicking ok and one bigger portion of the roof wasn't seems not joined but when I pressed ok and deleted it under was perfectly joined roof! Revit is so much about tiny details. Thank you for sharing, I will use this method moving forward it is so convenient. Is it something else I have to watch for during that process?
Do you think you also can help me with the way to create a roof saddle? shown on Autocad drawing? I circled it on Revit screenshot as well. Thank you
Message 12 of 17
I don't understand what condition or non-condition you are referencing.
This area?
Message 13 of 17
tegorovaB77X2
I didn't model it right yet- the elevator shaft walls should go higher and then to avoid accumulating water I need to create a roof saddle as shown on Autocad drawing in the first post in this area.
Message 14 of 17
You mean like this?
I just put the roof back where it was originally and Attached the Walls to it.  Had to make some minor adjustments to Walls though.
Message 15 of 17
tegorovaB77X2
yes! and then where two walls of this shaft that we don't see here attached intersect roof I need to model roof saddle similar to the pic.
Message 16 of 17
Do you have full Revit? If so, model the cricket as a flat roof and use Modify Sub-Element tools to shape it.
If not, just use the Join Geometry tool to join a sloped roof to the Main Roof.
one showing only roofs in view:
Message 17 of 17
If that solves for you, please mark my post as another accepted solution.   Okay?
Thx.
