Roof error
Roof error
bugarart000
Message 1 of 19
Roof error
bugarart000
Whenever I try to add a roof to my house, it always shows up on the second floor, even when I set the base level to my roof. I horizontally split my walls so I could paint them different colors.
Replies (18)
Message 2 of 19
What is the question?
If you want to finish the roof then just finish the footprint to get it done, then change it to the Roof level after.
Message 3 of 19
bugarart000
The question is how do I move my roof so that the base level is at the roof. I know there's a property constraints box on the side by it's on roof and it's showing it's on the second floor. It says footprint error whenever I try to make the roof too. I think my problem is rooting from when I horizontally split my walls.
Message 4 of 19
Splitting the walls is not the problem.  If you want to draw the roof the the roof level then you need to be doing it in the Roof Level Floor Plan.  Again, it is not that important, you can draw it at any level and change it to Roof after you done.
For the footprint error, you may want to clean up here:
- red side: only 1 line needed, not 4
- blue side: 1 not 2
If that still doesn't fix it, TAB on the footprint and share the screenshot.
Message 5 of 19
@bugarart000 wrote:
I'm pretty sure you have overlapping sketch linework in above screenshot. You can't do that. Must be a closed loop comprised of contiguous segments with each segment being only one line.
...you know, it might also be that one or more of those lines has an odd slope.  Are all the slopes the same?
Message 6 of 19
Expand the error message to read further info about the specific errors.  Revit may even be able highlight the specific areas where the sketch fails.
FWIW:
Message 7 of 19
Message 8 of 19
bugarart000
I looked and all the slopes are the same. It still shows the error even when I combines the lines at the top and left side.
Message 9 of 19
I can see in the screenshot that you are missing a line.  Post your file here and let me look it over.
Message 10 of 19
bugarart000
I attached my file. Thanks for trying your best to help so far
Message 11 of 19
Nothing is attached.
Message 12 of 19
bugarart000
How about now
Message 13 of 19
No issues.  See attached.
Message 14 of 19
bugarart000
Can you record yourself doing it or something because it won't work for me at all
Message 15 of 19
Message 16 of 19
I think mine looks prettier, but whatever floats your boat.
Message 17 of 19
other guy's roof might be difficult to frame as well.  Just saying.
Message 18 of 19
bugarart000
Thank you for the video super helpful. So how do I now make it look like yours, like the bay area more symmetrical like yours.
Message 19 of 19
I added a line and adjusted overhangs.  There's no one solution here though. Play around with it until you are satisfied.
