Sloped Slab with Integrated Water Tank
Hello all. Trying to integrate a built in water tank to a slab (see attached images). Currently these are two separate slabs, no sloping on the top and no sloping on the bottom (image 1). I'm trying to make it look like (image 2, which is currently done with a filled region) the idea is that the existing slab would dip down create a void for the built in tank. However I'm having a hard time understanding how this would be modeled as a single slab as most editing elements edit the top of the slab, not the bottom. My first thought is that this floor is simply made with several slabs, but even then how would I get a slab that is flat at the top and is sloped on the bottom...is the only solution a slab edge?
