Roof end - how do you make it square?
Message 1 of 9
How do you make the roof end so that it has  a square cut?
see attached picture. Thank you.
Replies (8)
Message 2 of 9
Message 3 of 9
Model In-Place Void works too.
TIP: Cut the Roof  with the Void (using Cut Geometry) BEFORE closing out of In-Place Editing Mode.
Message 4 of 9
I tried your method but it makes a setback on my roof edge. Is there a way to get rid of this setback?
Red is where the roof should end.
THANK YOU SO MUCH for getting me one step closer to my solution!
Message 5 of 9
I'm trying to fill the void but thank you so much for your reply. Appreciate all your help!
Message 6 of 9
Draw your roof longer first so then you square it off it remains correct.
Message 7 of 9
You don't "fill the void". But it's the wrong approach anyways. I thought the red portion was what you wanted to REMOVE -- not ADD.
Message 8 of 9
Why don't you just do a Square Cut?
...I'll bet you couldn't get the top roof eave to line up with the bottom roof eave.  Another way to do the top roof would be as a Roof by Extrusion. Make aligning the square cuts a lot easier.  FWIW.
Message 9 of 9
I just tried 'roof by extrusion' but I realized I can't use this command because my roof is a hip roof.
Thank you for your suggestion though! I truly appreciate all your feedback and advice! Than you so much!
