Roof edge
Roof edge
MortenLundehøjMøller_ODL
Roof edge
Community Visitor
Community Visitor
Hi
I have a roof construction 40 mm wood an 400 mm insulation.
In 3D views revit use the wood materil at edges. Is possible to change that so Revit use the insulation material.
vh - Morten DK
Use the Paint Tool and paint a material on the edges.
How did you create the assembly?  Stacking different roofs or cutting one roof with void?  Knowing that may reveal faster approaches then manually repaint the surfaces.
I guess Painting the few exposed edges in those 2 Views would take some time.  Might need a lunch break in-between.
...actually, if he means the edges shown in Section 1 View, then use Override Graphics in View to change the Cut representation.
Community Visitor
Community Visitor
Hi ToanDN
The Roof are created as one roof cutting with void.
Best regards Morten
