Shape of a wall
Shape of a wall
ferhatkarakaya
Shape of a wall
ferhatkarakaya
Hi guys,
I want to ask if someone knows how to change a walls properties for it to be wider on the bottom and thinner at the top?  As shown in the images.
I managed to do it as a body mass, but I want to have it as a wall itself. I would appreciate any tips and tricks 🙂
I also tried the command "edit profile" but it just works with the other side of the wall, so basically what i need is kind of like an extrusion of this trapeze.
What version of Revit are you using? 2022 can do this with Walls now.  Taper and Slanted.
Another way to do it, is as an In-Place Modeled Sweep Extrusion.  The cross-sectional shape is the Sweep Profile.  You can then categorize the In-Place as a Wall.  Also, you can assign a Project Material to the Sweep geometry.
It can be done as a slanted wall in Revit 2022.
In older version, you can use slab edge, railing, in place model, wall sweep.  Slab edge looks like the most appropriate choice given what you show.
ferhatkarakaya
Awesome it worked with the Sweeping!
I use Revit 2022, but tried it with the sweeping and it worked out so smooth
ferhatkarakaya
Thanks a lot!
