Roof Drains in Plan
Roof Drains in Plan
PhilvK
Advisor Advisor
Roof Drains in Plan
PhilvK
Is there a better way to show roof drains in plan than to just draw detail or model line circles?
Use a face based family. Revit most likely has some OOTB.
chrisplyler
Not sure what problem prevents your roof drain family from showing up. Are you trying to show a roof drain on a lower floor plan or something where they aren't normally visible?
tkienas
I would like to know how to do that.
It is basically a flat roof with modified sub-elements (raised points/edges) to create the cricket slopes, and a roof or face based drain family.
https://knowledge.autodesk.com/community/screencast/59dcbed1-b777-4e4f-9971-0a008ff61075
